Milling Solution for Hardened Metals
The Excelerator milling systems, which uses WG-600 whisker-reinforced ceramic inserts, is designed for high-performance milling in difficult-to-machine materials.
New Product From: 4/5/2011 Modern Machine Shop
The Excelerator milling systems, which uses WG-600 whisker-reinforced ceramic inserts, is designed for high-performance milling in difficult-to-machine materials. Typical applications include hardened materials above 40 HRc as well as nickel- and cobalt-based superalloys. The WG-600 whisker-reinforced ceramic inserts are effective for both roughing and finishing of high-strength alloys and hardened steels. These inserts are use a coated AL2O3 whisker-reinforced ceramic that delivers better tool life than uncoated whisker-reinforced ceramic inserts, the company says.
Greenleaf Corporation
MMS Zones
Zones
Supplier Categories
ERIX tool saves up to 90% of the manufacturing time on back spotfacing and chamfering operations.
Standard grooving tools from .004" in .001" increments with any corner radius. We stock more than 100,000 tools!
Premium tooling and technology for high-quality, precision machining.
