Milling Tool's Hooked Flute Geometry Aids Chip Formation, Evacuation
Eastec 2019: OSG’s ExoPro UVX-Ni features a variable helix and variable index design to reduce vibration, along with a flute form engineered to facilitate chip shaping and evacuation.
OSG’s ExoPro UVX-Ni features a variable helix and variable index design to reduce vibration, along with a flute form engineered to facilitate chip shaping and evacuation. Its cutting edge geometry further reduces cutting heat and forces, allowing it to achieve stable performance in difficult-to-machine materials such as Inconel 718, the company claims. A hooked flute form effectively curls and evacuates chips in applications ranging from side milling to slotting. The tool’s core strength provides resistance to deflection, while corner protection enhances tool life by strengthening the corner edge.
Grooving Attachment Streamlines Operation by 75%
A grooving attachment enabled Keselowski Advanced Manufacturing to reduce cycle times by over 45 minutes on a high-value, high-nickel part feature.
Best Practices: Machining Difficult Materials
