Mills and Lathes with CNC Technology Increase Productivity
Southwestern Industries will exhibit its Trak line of mills and lathes featuring the company’s ProtoTrak conversational CNC language, designed to reduce time-consuming machine setups and enable less-skilled machinists to do higher-level work.
Southwestern Industries will exhibit its Trak line of mills and lathes featuring the company’s ProtoTrak conversational CNC language, designed to reduce time-consuming machine setups and enable less-skilled machinists to do higher-level work. In addition to Trak bed mills, knee mills, lathes and 2OP portable VMCs, and retrofit products, the company offers the Trak LPM VMC, designed specifically for high-mix, low-volume work.
Heavy Engineering: The Complex Logistics of Moving Large Machine Tools
One of our fascinations with large-format machine tools has little to do with their capabilities, but everything to do with the logistics involved with getting them up and running. Here’s how one of the world’s oldest builders of giant machine tools tackles the challenge.
