Mitee-Bite Adds Long-Length Grip for TalonGrip Jaw Set
Mitee-Bite’s TalonGrip long-length serrated grip are designed to fit with the original 6" TalonGrip jaw set and provide line contact with the full length of workpiece.
Mitee-Bite’s TalonGrip long-length serrated grip is designed to fit with the original 6" TalonGrip jaw set and provide line contact with the full length of a workpiece. The long grips are compact (0.750"/19 mm) and designed to be placed anywhere in the jaw whenever specific tooling clearance is required.
The grips are manufactured from S7 steel, heat-treated and then finished with a black oxide coating. Each grip is laser engraved with a 10-mm scale, giving the user multiple reference points when repeatable part placement is required.
The company added long grips to the TalonGrip series after receiving customer requests for such a product.
Fixturing Castings Made Simple Through Adhesive Workholding
