Modular Clamp Holds Parts At Any Position
Strong Hand Tools introduces the Third Hand Modular Clamp, a fully articulated and adjustable modular clamp for holding parts at any position for hands-free access while the operator tack weld, cuts, grinds, sands or paints.
New Product From: 7/22/2014 Modern Machine Shop, ,
Strong Hand Tools introduces the Third Hand Modular Clamp, a fully articulated and adjustable modular clamp for holding parts at any position for hands-free access while the operator tack weld, cuts, grinds, sands or paints. Two smooth ball joints in the clamp enable the operator to rotate the clamp arm 360 degrees and bend the arm to any position that will give full access to the part for tack welding, repair, inspection or finishing processes. It can be locked and unlocked with a turn of socket head cap screws. The slim profile (1 ½" wide) enables it to be used anywhere in the shop, the company says. The universal C-clamp base (2" opening) supports mounting on a flat, square or angled surface.
More technology – a lot more!
IMTS 2014 will be the year’s largest showcase of new product technologies and new process innovations. If you’re looking for machining, tooling, systems, software, solutions and more, you’ll find it at IMTS 2014.
Learn More about IMTS 2014
Register Now
for IMTS 2014
Strong Hand Tools
Zones
  • Techspex
