Modular Interface for Cutting Tool Heads
Haimer and Kennametal introduce the new modular Duo-Lock interface for carbide cutting tool heads.
Haimer and Kennametal introduce the new modular Duo-Lock interface for carbide cutting tool heads. This modular tool system is said to provide maximum stability, load capacity and high runout precision based on a thread design with a proprietary double-cone connection and an additional third supporting area in the back of the interface.
The companies offer a new portfolio of cutting heads and mono-block screw fit tool holders with the Duo-Lock technology in all relevant spindle interfaces and extensions. Also, new modular cutting tool heads with longer length than currently available will be added to their product portfolio in order to enable shops to take aggressive cuts in aerospace and energy industry parts, the companies say.
The system provides 5-micron runout and a Z-axis accuracy of 10 microns, which is said to eliminate most of the expensive presetting processes. The companies say it offers increased metal removal rates at milling applications and longer tool life, achieving high performance comparable to latest-generation solid carbide endmills.
Making the Most of Mixed Toolholder Assemblies
While nearly all ER systems will have cross compatibility, they’ll have small differences across manufacturers that make their implementation at the shop level not as standard.
Haimer USA Models a Streamlined Toolroom
Haimer USA is celebrating its 20th anniversary with a live demonstration of its digital toolroom. Find out more past the aluminum panther.
Big Daishowa Chuck Eliminates Chatter in Milling Operations
The Mega 12DS chuck is designed for trochoidal milling with anti-vibration end mills.
