Modular Water Manifold Features Flexible Design
PCS Company will showcase its Kool Flow manifold, an anodized aluminum water manifold designed using six modular block assemblies.
PCS Company will showcase its Kool Flow manifold, an anodized aluminum water manifold designed using six modular block assemblies. The flexible design is said to reduce assembly times and enables modifications “on the fly.” Each Kool Flow system can be easily modified to add or subtract ports as needed, and o-ring seals are installed to protect against leaks between modular block assemblies.
