Monitoring System Automatically Adjusts Coolant
PRAB’s Automatic Coolant Concentration Control (AC3) continually monitors coolant concentration levels and adjusts automatically.
PRAB’s Automatic Coolant Concentration Control (AC3) continually monitors coolant concentration levels and adjusts automatically. According to the company, the unit is capable of maintaining programmed ratios within ±0.5 percent accuracy by taking continuous concentration measurements using an automatic refractometer. Readings are analyzed by a series of algorithms built into the software package, and actions such as opening and closing valves or turning on and off pump delivery systems are performed automatically. The coolant control works in conjunction with PRAB’s Guardian central coolant recycling system which uses a comprehensive coalescing filtration process.
STLE To Host Metalworking Fluid Management Program
STLE’s program is a two-and-a-half-day education program offering a comprehensive overview of metalworking fluid management.
Oelheld Coolant Increases Metal Removal Rates
The odorless coolant is said to offer increased removal rates, lower electrode wear, excellent surface qualities, lower refill quantities and longevity to provide lower overall operating costs.
Master Fluid Solutions Introduces Emulsion for Grinding and Cutting Operations
Trim E860 is said to be an ideal solution for heavy-duty and general machining.
