Mounted Grinding Points for Surface and Edge Grinding
Pferd offers an extensive line of vitrified and resin-bonded mounted points designed to meet an array of application needs for use in both surface and edge grinding.
Pferd offers an extensive line of vitrified and resin-bonded mounted points designed to meet an array of application needs for use in both surface and edge grinding. The mounted points can be used on various materials ranging from stainless steel and cast iron to exotic alloys. To meet these varied application needs, the mounted points come in a range of grain types, grit sizes, bond harness and shapes. They are said to provide high stock removal rates, high edge holding, dimensional stability and cool grinding to reduce the thermal load on a given workpiece.
The mounted points are available in a variety of abrasive grains and blends, including ceramic oxide for use in aerospace applications.In addition to industry-standard shapes, Pferd can customize its mounted point shapes and offer special bonds and variations in hardness, grit size and dimensions. A range of shank extensions are available for easier work in hard-to-reach areas such as inside castings and pipes.
Okuma
MMS Top Shops
The view from my shop.
Okuma
