Multifunction Tool Line Available in Inch Dimensions
Originally introduced in metric configurations, Carmex’s Mini Tools line is now available in standard inch dimensions.
Originally introduced in metric configurations, Carmex’s Mini Tools line is now available in standard inch dimensions. The Mini Tools line joins the company’s Tiny Tools and Swiss-Style tooling in an expanded selection of high-precision, multifunction tools designed for small size applications and Swiss-type machining.
The long-reach carbide shank toolholders equipped with through coolant combined with quick-indexing coated inserts enables threading, turning, grooving, boring and chamfering in both conventional and hard materials. Due to the toolholder, threads with large pitch and profile, long thread generation, and applications requiring overhang can be machined with vibration resistance and long reach, the company says. Mini Tool inserts feature BLU submicron-grade carbide and triple-layer PVD coating for high heat resistance, smooth cutting operation and long tool life.
Sumitomo Offers Quick-Change System, Chipbreaker for Swiss-Type Machining
The PSZ Turn System offers products for front-turning, grooving, thread-cutting and back-turning applications. Additionally, the MEFF Chipbreaker enables excellent chip control, low cutting force and good surface finish at a range of depth of cuts.
Tungaloy Expands Turning Tool Lines With Left-Handed Inserts
The TCS18 and TCL18 inserts are designed for left-hand cuts, expanding product lines that previously offered only right-hand inserts.
Buying a Lathe: The Basics
