Multitasking Machine Features Boring Capabilities
The Quick Turn Nexus 450-II MY is the largest of the company’s Nexus series of turning and multitasking machines developed for the oil and gas services and construction machinery industries.
New Product From: 8/4/2011 Modern Machine Shop
In addition to turning and milling, the machine also features boring capabilities for long, large-diameter shaft-type workpieces. Its combination tailstock, equipped with a bull-nose center and a 40" boring bar, enables deep-hole boring to depths ranging to 31.5". The machine’s headstock features a 7.2" through-bore size and a 50-hp integrated spindle motor that provides 2,000 rpm maximum speed. Optional 18" or 21" chuck sizes are available. Together with the Y-axis travel of a 12-position milling turret, the spindle is used as a C axis, capable of being indexed at 0.0001-degree increments to position workpieces for square-facing and slotting cuts, and off-center-line drilled holes.
Also on display will be the Orbitec 20 valve production center, which features a headstock spindle design and optional two-pallet changer.
Mazak Corp.
MMS Zones
Loading the player ...
