Multitasking Turn-Mill Center for Many Applications
The Hyperturn 45 high-production turn-mill is designed to accommodate barstock ranging to 45 mm in diameter for a range of applications.
New Product From: 2/21/2011 Modern Machine Shop
The machine’s two turrets can accommodate a total of 24 driven tools. Other features include a VDI25 rapid change system; 70-mm, Y-axis travel in the upper slide system; and a Z2 axis in the lower slide system. A 45-mm (standard 32-mm) through-hole counterspindle is available for longer parts. Also, the machine features various automation options.
The main and counterspindles are equipped with integrated water-cooled spindle motors with 15-kW drive power, 7,000-rpm speeds and 100-Nm torque.
The machine offers dynamic digital drives, a thermo-symmetrical machine construction, compact dimensions and several automation options.
Emco Maier Corp.
MMS Zones
