Multitasking Turning Center for Medium, Large Gears
Mazak’s Quick Turn Nexus 250-II MSY multitasking turning center is said to handle virtually all gear production processes from raw material input through final machining.
Mazak’s Quick Turn Nexus 250-II MSY multitasking turning center is said to handle virtually all gear production processes from raw material input through final machining. The turning center’s maximum machining diameter measures 13.78" for processing medium- to large-sized gears. The MSY configuration features milling and Y-axis capability as well as main and second turning spindles.
Mazak will also display its Integrex i-300ST five-axis multitasking machine capable of producing medium- to large-sized gears in single setups.
Controlling Extreme Cutting Conditions in Large-Part Machining
Newly patented technologies for controlling chatter and vibration during milling, turning and boring operations promise to drastically reduce production time and increase machining performance.
