Multitasking Turning Center Offers 18" Chuck, Heavy-Duty Machining
Mazak’s QTN 450M turning center with multitasking “Done In One” capabilities is said to boost productivity and reduce cycle times for large-diameter, shaft-type part manufacturing in industries such as oil and gas.
Mazak’s QTN 450M turning center with multitasking “Done In One” capabilities is said to boost productivity and reduce cycle times for large-diameter, shaft-type part manufacturing in industries such as oil and gas. The machine provides high-performance and value through its single-setup turning and milling operations that enable improved throughput. The machine is equipped with a 457-mm (18") chuck mounted on a 50-hp, 2,000-rpm main turning spindle with integrated motor for heavy-duty metal removal. The spindle is a full-function, CNC-controlled C axis for milling, and it indexes at 0.0001-degree increments to accurately position parts for square facing and slotting cuts as well as precisely drilled holes.
With a 12-position drum turret and 10-hp, 4,000-rpm rotary tool spindle, the machine performs milling, drilling and tapping operations for efficient single-setup part processing.
Mazak’s Mazatrol SmoothX CNC is said to enable faster and easier programming in either EIA or Mazatrol conversational, contributing to overall shorter part cycle times. It features several advanced functions that include High Gain Feed Forward Control, Fast Rotary Axis Speeds, Variable Acceleration Control and Intelligent Pocket Milling.
Swiss-Type Control Uses CNC Data to Improve Efficiency
Advanced controls for Swiss-type CNC lathes uses machine data to prevent tool collisions, saving setup time and scrap costs.
