Multitasking with Enhanced Lathe Features
GibbsCAM MTM (multitask machining) now includes lathe features that are said to provide more efficiency through tool control and take advantage of newer high-tech cutting tools that turn harder materials and machine smoother surfaces.
Article From: 3/4/2009 Production Machining
GibbsCAM MTM (multitask machining) now includes lathe features that are said to provide more efficiency through tool control and take advantage of newer high-tech cutting tools that turn harder materials and machine smoother surfaces. Among the features is a ProAXYZ module that enables MTM users to program thread whirling attachments on Swiss-type machines, thereby eliminating the complexity of time consuming, manual code modification at the machine control, the company says.
Also, as a result of the company’s collaboration with Mazak, Mori Seiki and Tornos, the MTM module now includes features to support advanced machines from these partners.
Turning features include advanced entries and exits; entry feed rates; enhanced no-drag; clean-up pass; multi-pass plunge roughing; notch ramp roughing; offset contour and tool edge path contour; threading entry and tapping tools; and groove-tool deflection compensation. New additions to Sync Manager and Op List, and new Op Manager associativity, make multitask machining easier and more efficient with the added flexibility, the company says.
Gibbs and Associates
MMS Zones
Zones
Supplier Categories
• 2-5 Axis Milling
Increase your productivity and bottom line with SURFCAM!
www.surfcam.com
Get the Edge with iMachining - the revolution in CNC Machining. Time savings up to 70%!
CAMWorks 2012
Smart, easy and efficient CAM software for manufacturing
SmartCAM V18.5 features New Mill/Turn Sub-Spindle and B-axis Support, Morph Pattern Roughing.
NX CAM Test Drive – Free full version of NX CAM - Intro to NX CAM Booklet & Complimentary online training
Loading the player ...
Simulate, verify, & optimize CNC machines with VERICUT
