Oil Lubricant Designed to Benefit Aluminum Machining
Unist has expanded its line of MQL lubricants with Coolube 2210AL, an oil specifically formulated for use with aluminum.
Unist has expanded its line of MQL lubricants with Coolube 2210AL, an oil specifically formulated for use with aluminum. Like all of Unist’s fluids, it is derived from natural vegetable oils user and environmental friendliness without VOCs. According to the company, this oil provides specific benefits when machining aluminum, including high lubricity and stability under load, which helps to improve tool life. The lubricant has a mild odor, a clear appearance and a flash point above 199°F (93°C). It is available in a variety of containers ranging from 1 quart to a 55-gallon drum.
STLE Opens Registration for 2024 Annual Meeting
The Society of Tribologists and Lubrication Engineers’ 2024 STLE Annual Meeting & Exhibition will take place May 19-23 at the Minneapolis Convention Center in Minneapolis, Minnesota.
STLE To Host Metalworking Fluid Management Program
STLE’s program is a two-and-a-half-day education program offering a comprehensive overview of metalworking fluid management.
STLE Hosts Co-Branded Tribology, Lubrication Events
The 2023 STLE Tribology Frontiers Conference and Tribology & Lubrication for E-Mobility Conference will provide attendees with two opportunities to share and learn the latest tribology and lubrication engineering science.
