Optical Touch Probe for Large Machining Centers
Marposs will showcase the Mida VOS optical touch probe system for use on large three- and five-axis machining centers.
Marposs will showcase the Mida VOS optical touch probe system for use on large three- and five-axis machining centers. The multi-channel system consists of a receiver with integrated interface and a transmitter unit that is compatible with Mida touch-trigger probes. As many as four transmitter/probe units can be used in an application with only one receiver, the company states. For machines with multiple spindles, two probes can be used simultaneously, making it is possible to implement two applications on the same machine. The system is controlled entirely by the machine tool via a simple PLC command, and the receiver can be easily programmed using a remote-control unit.
The Mida VOS is designed to reduce interference, and its modulated optical transmission system increases the operating range and transmission angle. Carbon extensions as long as 1 m can be used with the VOP60 modular transmitter/probe unit for reaching into deep bores. The system is available in both a compact and modular version for application flexibility.
MMS Top Shops
The view from my shop.
