Oven Cost
Please explain how to calculate the heat load capacity of a paint baking oven, using aluminum alloy wheels as an example.
Ask an Expert From: 11/6/2012 Products Finishing, Rodger Talbert, from Products Finishing magazine
Q. Please explain how to calculate the heat load capacity of a paint baking oven, using aluminum alloy wheels as an example. H.T.
A. Energy consumption in an oven is primarily related to radiant loss through the oven panels; energy required to raise the product, racks and conveyor to temperature; and exhaust losses. To determine the energy use, you will need to calculate these three factors and then add them to get the total.
Panel Loss
To calculate the loss of Btu/h through the oven panels, multiply the total square feet of oven panel surface area by the panel loss factor (see table) and then by the temperature difference between the oven start-up and the controller setting.
Panel ThicknessLoss Factor
3 inches0.40
4 inches0.35
5 inches0.30
6 inches
0.25
8 inches0.20
Formula: Square feet of oven surface × panel loss factor × temperature rise
Example
Oven Size: 20 × 50 × 10 ft (W × L × H)
Operating Temperature: 300°F
Oven Start-up Temperature: 70°F
Panel Thickness: 4 inches
Oven Surface Area
Sides: 10 × 50 = 500 × 2 sides = 1,000
Ends: 10 × 20 = 200 × 2 ends = 400
Top and bottom: 20 × 50 = 1,000 × 2 = 2,000
Total: 1,000 + 400 + 2,000 = 3,400 sq ft
Temperature Rise
300°F - 70°F = 230°F
Panel Loss
3,400 sq ft surface area × 0.35 panel loss factor × 230°F temperature rise = 273,700 Btu/hr
Product Loading
To calculate the Btu/hr required to support the product loading, multiply the total load (parts, rack, conveyor chain and trolleys) by the specific heat (Btu required per lb °F) by the temperature rise. The factor 0.226 is used for aluminum. Different materials will require a different multiplier, and the table below shows the specific heat values for different metals.
Specific Heat of Metals
MetalSpecific Heat
Steel0.12
Aluminum0.226
Iron0.175
Zinc0.0931
Chain & Trolley Weight
ConveyorChain Weight/FtTrolley Weight
Enclosed Track3.5 lbs0.5 lbs (H-Attach)
X3482.14 lbs2.34 lbs
X4583.14 lbs5.18 lbs
X6786.39 lbs16.5 lbs
Formula: Total load × specific heat × temperature rise
Example:
Chain: X348
Trolley Centers: 12 inches
Racks: 5 lbs on 12-inch centers
Parts: 5 lbs on 12-inch centers
Line Speed: 10 ft/min
Oven Temperature: 300°F
Total Load
Chain Weight: 2.14 + 2.34 = 4.48 lbs/ft
Parts and Racks Load: 5 + 5 = 10 lbs/ft
Total: 4.48 lbs chain and trolleys + 10 lbs parts and racks = 14.48 lbs/ft
Total product load/min: 14.48 lbs/ft × 10 ft/min = 144.8 lbs/min
Product load/hr: 144.8 lbs/min × 60 min = 8,688 lbs/hr
Temperature Rise
Btu/Hr
8,688 lbs/hr total load × 0.12 specific heat × 230°F temperature rise = 239,789 Btu/hr
(0.12 is the multiplier used for steel.)
Exhaust Loss
The exhaust loss is determined by multiplying the cu ft/min of exhaust (cfm) by 60 min by 0.075 lbs/cu ft by 0.24 Btu/hr per pound by the temperature rise in °F.
Formula: cfm × 60 × 0.075 × 0.24 × temperature rise
Example:
Exhaust Volume: 2,000 cfm
Set Temperature: 300°F
Temperature Rise
Exhaust Loss
2,000 cfm × 60 min × 0.075 lbs/cu ft × 0.24 Btu/hr × 230°F temperature rise = 496,800 Btu/hr
Total Energy Use
To determine the total Btu/hr consumed, add the three factors: panel loss, product loading and exhaust loss. In the above examples, this total would be:
273,7000 + 239,789 + 496,800 = 1,010,289 Btu/hr
To determine the actual cost, you must multiply the consumption by the cost for the energy used in the oven. The cost for energy varies widely in different regions. It was an average of about $2.80 per million Btu the week ending August 15, 2012.
