Parts Collector for Lights-Out Machining
The Rota-Rack is a device that enables any bar-fed CNC lathe to run unattended for extended periods of time.
New Product From: 6/15/2010 Modern Machine Shop
The Rota-Rack is a device that enables any bar-fed CNC lathe to run unattended for extended periods of time. The unit indexes each time a finished part exits the machine, safely collecting and protecting finished workpieces. It consists of a heavy-duty, welded steel turntable, a solid-state PLC control and an optional integrated conveyor. All contact surfaces are covered with a high-lubricity plastic for workpiece protection. The one-meter diameter turntable provides over 850 square inches of usable surface area and has a payload capacity of 700 lbs.
The design of the device enables it to be used with any CNC lathe that is equipped with a parts catcher. The unit, which operates on standard 110 V electrical power, can be mounted either to the left or right side of the machine and can be adjusted to heights ranging from 11" to 50".
Register Now for IMTS 2012
More technology – a lot more!
Learn More about IMTS 2012
Royal Products
MMS Zones
Royal Products
Zones
