Pneumatic Vise Designed for CMM Inspection
The Rapid-Loc pneumatic vise from Phillips Precision holds workpieces for CMM inspection with soft jaws that can be customized to hold virtually any part.
The Rapid-Loc pneumatic vise from Phillips Precision holds workpieces for CMM inspection with soft jaws that can be customized to hold virtually any part. Designed to take advantage of a CMM’s air supply, the vise’s regulated air pressure can produce just enough clamping force to hold delicate parts or, if needed, generate as much as 150 lbs. The black anodized aluminum pneumatic vise offers a 2.5" × 3.5" footprint and 0.06" travel and comes with one set of machinable aluminum soft jaws. The vise can mount on the company’s Loc-N-Load inspection setup using quick-swap fixture plates for fast, accurate and repeatable setups. Rapid-Loc can also be mounted on existing CMM breadboards and is securable with standard or metric thread screws.
Phillips Precision also offers a workholding kit for Vision Inspection that complements its Open-Sight, fast-swap fixture plate system. The kit includes Trigger-Finger and Trigger-Point hold downs, a clear acrylic platform for extending work out over the viewing area, hole adjusters, Sliding Stop and Spring-Loc stops and clamps for holding work on an optical stage.
  • Modern Bar Feeds Bring New Life to Automatic Swiss Lathes
    Cam-actuated Swiss lathes are still the fastest way to process many parts. By adding modern bar feeders, this shop has dramatically improved their utilization with the ability to work unattended, even in a lights-out environment.
  • A Case for Combining Workholding with Optical Scanning
    Automotive dies and die inserts are often complex, one-off parts with little room for error. Integrity Tool's investments in modular workholding tools and 3D optical scanning have allowed the company to create niche capabilities for its CNC machined parts.
  • Custom Workholding Principles to Live By
High Accuracy Linear Encoders
