Polishing/Deburring System Provides Mirror Finish
Gesswein’s Ultramax MF is a multi-function polishing and deburring system designed to reduce finishing time.
The polishing and deburring system is said to be unaffected by complex alloys and tungsten carbide. Everything from milled surfaces to rough EDM surfaces can be polished to a mirror finish, the company says.
Buying a Lathe: The Basics
