Product Line Lubricates, Cleans, Protects
Oelheld’s LubTool line includes products for lubricating, cleaning and protecting parts from corrosion.
Oelheld’s LubTool line includes products for lubricating, cleaning and protecting parts from corrosion. The company’s LubTool 2000 is a fully synthetic, polyalphaolefin-based lubricating oil that lubricates, cleans, protects and removes corrosion, even in low temperatures. The oil is free of silicon, acids and resins, and is neutral to all common plastic and elastomeric materials, the company says.
LubTool 4000 features a combination of active cleaning components for removing a range of contaminants. It is suitable for cleaning soiled machinery components as well as removing resin, oil and grease; most coatings; and paints and crayon marks. It can also be used for surface preparation prior to bonding and painting. The cleaner does not contain hydrocarbons and evaporates residue-free, the company says.
LubTool 6000 forms a thin, grease-like protective film to protect metal parts from corrosion during long-term storage indoors or outdoors. The coating does not contain FHC, CHC or FCHC and does not form resins. According to the company, the product can be easily removed after long-term storage, and treated parts can be cut via wire EDM without removing the coating.
Alliance Manufacturing's Cleaning Systems Use Safe Solvents
PMTS: The company’s vacuum degreasing machines use solvents to remove contaminants from manufactured parts without the use of water or scrubbing.
CTG's Parts Washing Machine Supports Lean Manufacturing
PMTS 2023: The Ransohoff LeanVeyor parts washing system reduces floor space requirements and provides optimized cleaning and drying performance.
Kyzen Solvents Provide Ease of Cleaning for Medical Parts
The Metalnox line of solvent products are designed to improve reliability and increase the ease of cleaning in vacuum and vapor degreasing processes.
