Product Lines Feature Quick-Change System
The EWS driven tool and static toolholder lines are available in both VDI and BMT styles. Within the product lines is the company’s Varia system, which is a quick-change system with a simplified, single clamping point connection system available for driven, static and special application EWS products. According to
New Product From: 8/6/2008 Modern Machine Shop
The EWS driven tool and static toolholder lines are available in both VDI and BMT styles. Within the product lines is the company’s Varia system, which is a quick-change system with a simplified, single clamping point connection system available for driven, static and special application EWS products. According to the company, the Varia System provides a reduction in setup and change-over time with its single clamping point. The system is designed so the tool head is changed with a 210-degree turn using a standard Allen key. Preset tools can be staged at the machine to further reduce downtime.
Standard static toolholders include OD turning toolholders; facing toolholders; cut-off toolholders; boring bar holders; U-drill holders; Capto tool blocks; and ABS toolholders.
 The driven radial and axial tool line includes ER collet holders; Weldon shank holders; Whistle-Notch; Capto; KM; ABS; and Gear Ratio 1:1 or several gear ratios and off-sets.
Command Tooling Systems/EWS
