Quick-Change, Three-Point Locking Tooling System
The Micro-Quik quick-change tooling system from Micro 100 Tool features a three-point locking and locating system engineered for maximum tool rigidity and centerline repeatability within +0.0005"/+0.01 mm from tool to tool, the company reports.
The Micro-Quik quick-change tooling system from Micro 100 Tool features a three-point locking and locating system engineered for maximum tool rigidity and centerline repeatability within +0.0005"/+0.01 mm from tool to tool, the company reports. The Micro-Quik System is said to reduce machine setups, downtime and tooling costs while boosting productivity and overall profitability.
Making the Most of Mixed Toolholder Assemblies
While nearly all ER systems will have cross compatibility, they’ll have small differences across manufacturers that make their implementation at the shop level not as standard.
T.J. Davies Retention Knobs Maximize Cutting Tool Life
Quick-Change Collet Chuck Doubles as Mandrel
The hybrid Comot-AZ quick-change collet chuck from SMW Autoblok can be used for OD machining and can be transformed into an expanding mandrel for ID clamping using the EMX series.
