Reduced Size Power Clamps
J.W.
New Product From: 8/9/2010 Modern Machine Shop
J.W. Winco offers the MN 130 series pneumatic power clamps from Misati, S.L. The RoHS-compliant, metric-sized clamps are made of C45 hardened steel with a black-oxide finish. They have a maximum pressure of 10 bar and work pressure of 6 bar. The smaller-profile, high-clamping-force, reduced air consumption clamps are suited for applications in assembly, verification, handling, robotics, machining, welding and more. The reduced size enables the clamps to achieve higher holding forces than other clamping options, the company says. Accompanying standard accessories can adapt the clamps to virtually all applications, such as molded, cast or machined surfaces, caustic environments, sensor requirements and others.
Register Now for IMTS 2012
More technology – a lot more!
Learn More about IMTS 2012
J.W. Winco, Inc.
MMS Zones
J.W. Winco, Inc.
Zones
Supplier Categories
