Mr. Colasanti and Mr. Cirino highlight diagnostic capabilities such as the ability to track scale feedback amplitude and frequency on the monitor as major benefits of this Heidenhain iTNC 530.
This machining center at Concours Mold has been retrofitted with Heidenhain components.
When it becomes imperative in a machining business to find ways to
improve production, there are always options. What is the best way to
make these improvements? Is obtaining the latest advances in new
equipment in order? If so, how much will that cost?
These
questions are commonly asked and answered by those in the industrial
machining business every day. While each situation has its own set of
incidentals, some common truths must be acknowledged, according Steve
Colasanti, systems integrator at Dual Electric & Refrigeration
Services, and Frank Cirino, president of Lomar Machine Repair. Both
companies are located in Tecumseh, Ontario.
“The cost of
upgrading a machine tool to almost new is typically a fraction of the
cost of buying new,” Mr. Colasanti says. “If you have a solid machine
base to work with, retrofitting machines with digital CNC and servo
technology can yield large decreases in cycle time while providing
accuracy similar to that of new machinery.”
Both Mr. Colasanti and Mr. Cirino should know, as they have been
doing just that as a team for almost ten years. “We at Lomar specialize
in mechanical service work for the tool and mould industry, and the
Dual guys are experts at the electrical end of things,” explains
Cirino.
Together, they have participated in the
successful implementation of more than 50 CNC machine retrofits plus
numerous DRO and scale integrations. Both have been working with Heidenhain
equipment for their entire careers. “We have many success stories that
we can share and many happy customers,” Mr. Colasanti says, citing
Concours Mold Inc. in Ontario as just one.
The teams’
experience with Councours Mold began in 1998, when they equipped a
large vertical milling machine with a Heidenhain TNC 426 analog system.
Since then, the company has called them back in to perform five other
major CNC retrofits, including one involving a machine identical to the
vertical mill mentioned above. Equipped with a high speed, PC-based
CNC, this mill took more than 300 hours to cut a large tool—a job that
its sister machine with the newly installed analog control could
complete in 180 hours. The company decided to replace the PC-based
control with a digital system, which reduced cut time to 110 hours—a
performance increase of more than 265 percent. After that successful
retrofit, Mr. Colosanti and Mr. Cirino also equipped the analog machine
with a digital control.
Both say that providing a high-quality digital retrofit begins in the
quoting stages. The first step is to investigate the mechanics of the
machine to determine the feasibility for a digital upgrade. Proper
inertia matching calculations for each axis drive system is essential
to peak high speed operation. “I never trust the original manufacturer
design as being accurate,” Mr. Colasanti says. Next, they must
understand the electrical system and how to properly integrate to it.
The goal is to provide a system with high performance and low downtime.
Talking about payback in retrofits is also important, Mr. Colasanti
says. “I always tell people that when you’re busy, payback is fast.
When you’re slow, payback is not as fast, but it is evident in shorter
tooling production times for your customers,” he explains.
In
addition, Mr. Colasanti says machine retrofits allows customers to stop
farming out jobs, which can result in substantial cost savings. He
cited one example in which Concours had to farm out a job that ran
around-the-clock at about $100 an hour, resulting in a total cost of
about $17,000 per week. After a digital retrofit, however, Concours
could complete the jobs more quickly, and that money stayed in-house.
The retrofit, which took about two weeks, held about a ten-week payback
and resulted in long-term savings.
In addition to CNC
retrofits, the two men also recommend linear scale upgrades, especially
for smaller milling machines. They say they use Heidenhain components
for these upgrades as well because of their ability to withstand harsh
industrial environments. A typical installation in a CNC application
includes proper mechanical alignment of the scale with custom-made
brackets for the reader head. A 1- or 3-meter armored cable on the
cable raceway connects to the CNC.
“When you start getting
into longer distances, machines taking measurements using rotary
encoders on the motors can lose accuracy,” Mr. Cirino says. “Ballscrew
and thermal expansion issues often come into play, and using a linear
scale as the measurement component instead is much more accurate.”
Mr.
Colasanti and Mr. Cirino also use Heidenhain components for DRO
retrofits, providing installations on knee mills, manual boring mills
and rotary tables. A recent retrofit for one customer involved
replacing three old DRO kits that were expensive to repair. John
Morris, shop foreman, says the new Heidenhain DROs keep everything
running smoothly and provide bolt-hole circle capabilities.
