Robots as Precision Machine Tools
To remain competitive, high-end manufacturing companies are looking for accurate, reliable and maintenance-free machine tools offering fast change-over, programming and setup. Industrial robot technology could provide an excellent base for machining because it is flexible and affordable.
Article From: 1/23/2012 Production Machining, Edited by: Chris Felix,
Editor's Commentary
For more information about the COMET project, visit www.comet-project.eu or follow the project's developments on Twitter (@Comet_project).
K-Series Optical CMM
Researchers at Fraunhofer IPA run tests using the K-Series optical CMM and a KUKA robot.
Infrared LEDs
The K-Series optical CMM is able to track infrared LEDs with 6 degrees of freedom at a sample rate of as much as 1,000 Hz.
COMET (Plug-and-produce COmponents and METhods for adaptive control of industrial robots enabling cost effective, high precision manufacturing in factories of the future), co-funded by the EU, is creating a solution that enables the use of industrial robots for high-end machining. Robots of any brand fitted with the plug-and-produce controller unit can respond to manufacturing industry needs for cost effective, flexible and reliable manufacturing solutions.
Nikon Metrology is a primary contractor for the program, developing an adaptive tracking system to detect deviations from the programmed robot path. This system is used to initiate real-time toolpath corrections to maintain the targeted accuracy throughout the entire machining sequence. The proposed COMET solution is estimated to be, on average, 30 percent more cost effective than dedicated machine tools, while delivering absolute positional accuracy better than 50 micron.
Industrial Robots
Combined with enabling metrology solutions, industrial robots offer distinct advantages over specialty equipment designed for specific machining tasks. As part of the COMET project, Nikon Metrology is responsible for developing an adaptive tracking system. The system helps adjust real-time robot arm positioning in relation to where it should be according to the initial programmed robot path.
The adaptive tracking system tracks the location of the robot head in real-time and feeds back the metrology data using a closed feedback loop via the controller. This metrology-adjusted process substantially increases robot accuracy because it almost eliminates the influence of robot warm-up, drift and backlash. It underlines the importance of the adaptive tracking system in transforming industrial robots into precision tools for milling, deburring and other machining applications. Such robots are in high demand in aerospace and automotive markets as well as manufacturing environments involved with mold and die and high-precision parts.
Real-Time Robot Motion Adjustment
The plug-and-produce robot control system is a modular system that fits most robot brands, including ABB, Fanuc and KUKA. Other modules that can be plugged in focus on kinematic and dynamic models to set up a unique robot fingerprint, a holistic programming and simulation environment and a high dynamics compensation mechanism to eliminate remaining positional errors.
The adaptive tracking system module consists of two components: the tracking system and the comparison and path adaptation module. Based on specific project needs, the tracking system research will start with the K-Series optical CMM from Nikon Metrology.
The K-Series pre-calibrated solid state camera system consists of three linear, built-in, charge coupled device (CCD) cameras. With cylindrical lenses on all cameras and the middle camera tilted 90 degrees, the optical CMM measures the locations of infrared light emitting diodes (LEDs) mounted on the robot head. As an LED is located where the 3 CCD observatory planes intersect at the instance of capture, the system is able to determine the point coordinates based on the plane inclination angles. The system offers the means to track multiple LEDs simultaneously with 6 degrees of freedom at a sample rate of as much as 1,000 Hertz to allow for dynamic measurements.
The module for the corrective adaptation continuously compares the measured position, speed and acceleration with the corresponding data in the part program. A model-based algorithm then determines when and how to adjust robot operation to meet the accuracy required by the machining process. Development efforts from Nikon Metrology engineers concentrate on measuring accuracy, system latency and module interfacing to obtain precise and prompt robot motion adaptations.
Ready to Go
The flexibility and cost efficiency of industrial robots is used by adding absolute position accuracy and a plug-and-produce software environment to design, program, simulate and execute high-end machining processes. New, innovative tracking components and modular ICT-based methods are being developed to open new application areas for industrial robots. These components and methods can be plugged into the modular platform, ready for use with any industrial robot cell.
The 30-month COMET project was kicked off in September 2010. After completing the plug-and-produce robot controller, Nikon Metrology will act as a partner in exploiting the project results. The project involves 14 technical partners from eight countries across Europe, coordinated by manufacturing software specialist Delcam.
Editor's Picks
Handling Parts In A Robotic Cell
Here’s a review of the workholding and workhandling challenges a shop faces as it moves a part through a robotic cell, from serving up the blanks to t...
Nikon Metrology
MMS Zones
Editor's Picks
Nikon Metrology
Zones
Supplier Categories
Marposs - Metrology equipment for improving productivity and reducing cost in manufacturing.
Learn how to solve the metrology problems of tomorrow today. June 4-7, Las Vegas.
Advanced form, contour, surface and shaft metrology.
Precision is our business. Test us.
