So what exactly is a Makino MMC? It’s a palletized automation system.
It will take a part from a work-setting station, where a raw part would
be loaded, for example, and move that part to an available machine or
to a pallet storage system to await an available machine. On the other
side, it will take a finished
side, it will take a finished part from a machine and place it for
extraction. In either case, the system does offer a pallet storage
system for raw or finished parts. The system requires an upper-level
software to manage and schedule parts for production. One of the key
elements, our customers tell us, is that once you get a job set up and
running, it stays resident in the cell controller software. What that
means is, once the data is entered, the software keeps everything in
memory so the next time you need to run the part, you just call up the
file and run it. Scheduling of work is another key element of the
system, allowing you to schedule short jobs to run during the work
shifts and longer jobs during shifts where labor is not present,
allowing your people to return to finished points and increase your
ability to produce more at a faster rate.
