Roller Conveyor Handles Large Components
Rosler’s RRB roller conveyor shot blast system is designed for descaling, rust and paint removal, and general cleaning applications.
Rosler’s RRB roller conveyor shot blast system is designed for descaling, rust and paint removal, and general cleaning applications. Sized to handle metal sheets, pipes, tubes, I-beams, channels and angles, the standard machine is capable of processing parts ranging from 2 to 14 ft. wide. It offers roller conveyor speeds ranging from 1.6 to 13 fpm, while high-performance systems offering speeds ranging to 24.5 fpm also are available. Custom blast turbine configurations ensure optimum blast results for thin-gauge aluminum, as well as heavy steel profiles and slabs. The machine width and the number and location of blast turbines can be customized based on the workpiece size and production speed.
NMP's Parts Cleaning Systems Pass Upcoming Regulations
PMTS 2023: ITF Parts Washing Equipment machines are designed to help prepare and sustain manufacturers for the upcoming environmental regulations in North America.
CTG's Parts Washing Machine Supports Lean Manufacturing
PMTS 2023: The Ransohoff LeanVeyor parts washing system reduces floor space requirements and provides optimized cleaning and drying performance.
Madison Chemical Degreaser Easily Removes Machining Oil
ProClean Degreaser quickly and completely removes oil and grease with its superior wetting and penetrating properties.
