Rotary Encoders Employ EtherCAT Technology
The Leine & Linde PSE and PHE 900 series of rotary encoders, available from Heidenhain, are designed for heavy-duty applications and are now available with an EtherCAT interface option.
The Leine & Linde PSE and PHE 900 series of rotary encoders, available from Heidenhain, are designed for heavy-duty applications and are now available with an EtherCAT interface option. The series of solid- and hollow-shaft absolute rotary encoders is said to be capable of operating in situations where high temperatures, moisture, vibration or shock are present.
The EtherCAT option on these rotary encoders provides angular position value on the machine. In addition, signal processing capabilities can deliver velocity, acceleration, alarms and warnings to the control system, providing multi-variable feedback for sophisticated control algorithms with cycle times as short as 31.25 msec.
  • Generating a Digital Twin in the CNC
  • Key CNC Concept No. 1—The Fundamentals Of Computer Numerical Control
    Though the thrust of this presentation is to teach you CNC usage, it helps to understand why these sophisticated machines are so important. Here are but a few of the more important benefits offered by CNC equipment.
  • 6 Steps to Take Before Creating a CNC Program
Gardner Business Intelligence
Gravotech
High Accuracy Linear Encoders
