The precision rotary grinding attachment converts surface grinding machines into a rotary grinding function. The attachment can be used on standard and CNC surface grinders and the unit fits into machines which have enclosed guarding arrangements and performs well under flood coolant conditions, according to the company.
The rugged design of the attachment is said to provide a high level of accuracy in respect to flatness and surface finish.
Features of the attachment include an inclinable sine table for quick angle settings 0 to 45 degrees; motor and electronic controller, waterproof to IP54 standard; and variable speed control 0 to 150 rpm.
