Rotary Indexing Table Uses Direct-Drive Motor To Eliminate Backlash
The GSI DNC-400 direct-drive rotary indexing table is suited for high-volume and aerospace manufacturers performing high speed, high-accuracy contouring operations. Compared to tables using a servomotor and worm gear, this direct-drive table offers higher accuracy, faster rotational speeds and higher torque, the co
New Product From: 8/6/2008 Modern Machine Shop
The GSI DNC-400 direct-drive rotary indexing table is suited for high-volume and aerospace manufacturers performing high speed, high-accuracy contouring operations. Compared to tables using a servomotor and worm gear, this direct-drive table offers higher accuracy, faster rotational speeds and higher torque, the company says. In addition, the direct-drive motor is built to eliminate backlash and deliver high servo stiffness. Without mechanical gearing, the table has fewer parts to wear.
The table delivers 200-rpm rotational speeds, 0.0004" spindle runout and 515-psi hydraulic pressure. Maximum torque is 590 foot-pounds, and brake torque is 1,844 foot-pounds. The clamping torque is said to ensure smooth machining without deflection under heavy loads. The table has a 15.75" table diameter and offers a maximum horizontal loading capacity of 1,100 lbs (661-lb vertical loading capacity).
CNC Indexing & Feeding Technologies
MMS Zones
Zones
Supplier Categories
Loading the player ...
Self centering vise is a cost effective and universal workholding method for five sided machining.
There's more on workpiece holding and positioning in the Techspex Resource Center.
