A Quick Way to Deburr Holes in Contoured Surfaces
This video shows a device that enables machine tools to quickly deburr both sides of through holes in elliptical and contoured surfaces.
View MorePhillips Corporation
The video above shows how COFA devices from Heule Tool enable machine tools to quickly and effectively deburr both sides of through holes drilled in elliptical and contoured surfaces.
As the rotating tool is fed into the hole, the front cutting edge deburrs the top of the hole and the blade rocks upward. The action of the blade cuts a smooth, tapered edge break from 0.010 to 0.030 inch, depending on the tool’s diameter.
While the blade is in the hole, only the ground and polished non-cutting ball touches the wall surface protecting the workpiece from damage while the tool is fed through the part. There is no need to stop or reverse the spindle. When the blade reaches the bottom of the part, its blade springs back into cutting position and the back cutting edge deburrs the bottom of the hole as the tool is withdrawn. Once the blade is back inside the hole, the tool can be rapidly removed and moved to the next hole.
These universal deburring tools use a proprietary TiN-coated carbide blade that is said to achieve fast feeds and speeds and provide long tool life. COFA tools are available sizes ranging from 0.157 to 1.614 inch (4 to 41 mm). A cassette option is available for larger holes.
Vollmer Ultrasonic Cleaning, Deburring System Provides Process Reliability
IMTS 2024: The UltraTec Ultrasonic A25 cleans and deburrs small and delicate components, making it well suited for applications in heavily regulated sectors with challenging demands.
Heule Tool Deburring Solution Enhances Main Bore Processing
Heule Tool introduces the Snap-X line, designed for advanced cross hole deburring of main bores with multiple intersecting bores at varying diameters and angles.
Mastercam Software Improves Programming Flexibility
IMTS 2024: Mastercam introduces Mastercam 2025, with features including Mastercam Deburr for automated edge finishing, finish passes, mill-turn support for Y-axis turning and automatic license update notifications.
