Grinder Performs Roughing, Finish Grinding in Single Setup
The Lean Selection machine available from Erwin Junker Machinery is suitable for grinding camshafts in any batch size.
New Product From: 7/11/2014 Modern Machine Shop, ,
The Lean Selection machine available from Erwin Junker Machinery is suitable for grinding camshafts in any batch size. The grinder is designed to perform rough and finish grinding in a single clamping setup to save time and increase accuracy. The machine grinds cams and bearings with flexibility and uses the orbital grinding method to support non-cylindrical grinding. It features CBN abrasive and oil coolant with grinding technology and offers cutting speeds of approximately 140 m/sec. as well as high feed rates resulting in short cycle times, says the company.
According to the company, the  high-power grinding spindle with 42-kW drive capacity is low-maintenance because it contains lifetime lubrication and air seal. The machine comes with the option of manual loading and contains user-friendly CNC controls that have a three-point mounting interface to promote fast change-over and grinding wheel concentricity.
See what you missed at IMTS 2014!
Check out IMTSTV for segments about the show and what’s new in the world of manufacturing technology, then watch Shop Talk to get the Modern Machine Shop editors’ take on IMTS, the trends they’re seeing, and what’s coming next in your industry.
Learn More about IMTS 2014
Erwin Junker Machinery, Inc.
Zones
  • Techspex
