Self-Contained Pneumatic Power Collet Chuck For Use With B60 Collets
  The self-contained pneumatic B60 power collet chuck does not require a lathe, grinder or rotary table to have a hydraulic system, rear actuator, restrictive draw-tube or air feed tubes. Instead, the collet chuck is operated by an air cylinder that is integrated into its body. The chucks have a gripping capacity
New Product From: 8/6/2008 Modern Machine Shop
The self-contained pneumatic B60 power collet chuck does not require a lathe, grinder or rotary table to have a hydraulic system, rear actuator, restrictive draw-tube or air feed tubes. Instead, the collet chuck is operated by an air cylinder that is integrated into its body. The chucks have a gripping capacity of 2.375".
Many new toolroom lathes or flat bed lathes come with a CNC but with manually operated chucks. These machines are not equipped with a hydraulic system to operate a power chuck. According to the company, its integrated pneumatic cylinder collet chuck is designed to easily convert these machines to a power collet chuck.
Also available are models that are said to accommodate 5C, 16C and B42 collets with high accuracy and speeds to 5,000 rpm.
Pratt Burnerd America
MMS Zones
Zones
Supplier Categories
Self centering vise is a cost effective and universal workholding method for five sided machining.
There's more on workpiece holding and positioning in the Techspex Resource Center.
