Self-Priming, Workholding Air/Hydraulic Pump
The company’s workholding air/hydraulic pump is suitable for fixtures or pallet systems. The maximum air inlet pressure of 120 psi yields a hydraulic output pressure of as much as 3,000 psi with hydraulic flow rates to 1 gpm. Hydraulic pressure can be adjusted via the built-in air pressure regulator. This self-prim
New Product From: 8/6/2008 Modern Machine Shop
The company’s workholding air/hydraulic pump is suitable for fixtures or pallet systems. The maximum air inlet pressure of 120 psi yields a hydraulic output pressure of as much as 3,000 psi with hydraulic flow rates to 1 gpm. Hydraulic pressure can be adjusted via the built-in air pressure regulator. This self-priming pump has a replaceable cartridge, 25-micron filter.
Vektek, Inc.
MMS Zones
Vektek, Inc.
Zones
Supplier Categories
Self centering vise is a cost effective and universal workholding method for five sided machining.
There's more on workpiece holding and positioning in the Techspex Resource Center.
