Semi-Synthetic Metalworking Fluid for Multi-Metal Substrates
Chemetall’s Tech Cool 35048BF semi-synthetic metalworking fluid is a 100-percent boron-free micro-emulsion formulated for improved lubricity and extended sump life.
Chemetall’s Tech Cool 35048BF semi-synthetic metalworking fluid is a 100-percent boron-free micro-emulsion formulated for improved lubricity and extended sump life. Designed for heavy-duty machining on multi-metal substrates, the fluid provides emulsion stability for more reliable operation. It offers effective tramp oil rejection, minimal foam, increased corrosion resistance, low residue and reduced consumption without the use of registered bactericides, dicyclohexylamine (DCHA), formaldehyde-donating compounds, chlorine, sulfur or boron. The fluid is said to be well-suited for the medical device, aerospace, automotive, off-road and general industries.
168 Manufacturing's Coolant System Automates Delivery
PMTS 2023: FullShop systems monitor and replenish all CNC machine sumps with optimized top-off ratios before the coolant runs low.
Jorgensen's Coolant Collection System Eliminates Sludge Build-Up
The PermaClean system adds agitation to the coolant collection system or holding tank and prevents particulates from settling.
