Seven-Axis Lathe Combines Swiss-Type CNC Machining with Laser Cutting
Tsugami/Rem Sales introduces the SS207-5AX LaserSwiss, a 20-mm, seven-axis Swiss-type CNC lathe with B-axis control.
Tsugami/Rem Sales introduces the SS207-5AX LaserSwiss, a 20-mm, seven-axis Swiss-type CNC lathe with B-axis control. The machine combines Swiss-type CNC machining with laser cutting, enabling both operations in a single setup. All operations are programmed and driven from the machine’s FANUC 31i-B5 CNC. According to the company, the lathe is designed to decrease cycle time and support part designs that couldn’t be machined with conventional methods.
The company will also display a selection of its Swiss-type lathes, gang/turret lathes and CNC turning centers.
Meet us at booth 338190 - CHIRON Group
