Shank Holders Offer Locational Accuracy ±2 Microns
Kyocera Precision Tools has introduced a line of polygon taper shank holders for high-rigidity and high-precision machining.
Kyocera Precision Tools has introduced a line of polygon taper shank holders for high-rigidity and high-precision machining. The KPC series features several holder styles for turning, grooving, cutoff and threading applications.
The special polygon taper design provides dual contact between the taper and the flange face along with an even distribution between three faces on the sides of the flange. The design is said to create a rigid body with locational accuracy within ±2 microns.
Haimer USA Models a Streamlined Toolroom
Haimer USA is celebrating its 20th anniversary with a live demonstration of its digital toolroom. Find out more past the aluminum panther.
Five Common Mistakes Shops Make with ER Collets (And How to Prevent Them)
Collets play a crucial role in the machining process, so proper tool assembly and maintenance is important. Here are five potential pitfalls to avoid when using ER collets.
