Short, Compact Spindles
The company offers short, compact spindles designed for use on CNC turn-mill centers. The EMS-3060A is 124-mm long, and it features an electric motor and 60,000 rpm. The PMS-3020A is 105-mm long, features an air motor and 20,000 rpm.
The company offers short, compact spindles designed for use on CNC turn-mill centers. The EMS-3060A is 124-mm long, and it features an electric motor and 60,000 rpm. The PMS-3020A is 105-mm long, features an air motor and 20,000 rpm. The EMA-3020S electric spindle features a compact, 90-degree angle head, 21,300 rpm and is 147-mm long. The EMA-3020K electric spindle features a standard 90-degree angle head, 21,300 rpm and is 156-mm long. All four 30-mm-diameter compact spindles are suited for machines with limited space.
Also available is the line of NSK/Nakanishi machine tool attachments plus hand tools used for deburring, polishing and grinding applications.
