Shrink-Fit Machine Accommodates ER Collets
Eastec 2019: Haimer USA’s shrink-fit machine, Power Clamp Sprint i4.0, is being marketed as an entry point into the Industrial Internet of Things (IIoT).
Haimer USA’s shrink-fit machine, Power Clamp Sprint i4.0, is being marketed as an entry point into the Industrial Internet of Things (IIoT). The machine is engineered to provide both ergonomic operation and integrated cooling for all types of cutting tools (for example, solid carbide and high speed steel, or HSS) in a short time. A special holding fixture enables use of the machine with ER collets, expanding the Sprint i4.0’s use to Swiss-type and live tooling.
The system features software said to simplify usability, an intelligent cooling system with temperature control, and a durable 7" touchscreen display. Users can also customize the Sprint i4.0 with a laser scanner to read and set shrinking parameters automatically. These capabilities are said to eliminate variation between tool changes, resulting in repeatable uniformity in tooling setup and therefore consistent quality results.
Simulation and Tooling Secure High-Value Work
Simulation software and careful attention to tooling parameters have enabled Major Tool to take on ambitious projects with its complex machinery.
GenSwiss Releases Redesigned Toolholding System
Its GenQuick quickchange ER system for Swiss-type CNC machines and precision machining equipment has been updated.
Quick-Change Collet Chuck Doubles as Mandrel
The hybrid Comot-AZ quick-change collet chuck from SMW Autoblok can be used for OD machining and can be transformed into an expanding mandrel for ID clamping using the EMX series.
