Single-Roll Burnishing Tool for Compact Spaces
Cogsdill’s UBT-T4 universal single-roll burnishing tool features a compact design for use where limited space is available.
Cogsdill’s UBT-T4 universal single-roll burnishing tool features a compact design for use where limited space is available. The turning-holder-style tool is designed for, but not limited to, use on multi-spindle automatic and screw-type machines.
The product is available in both left-handed and right-handed models for burnishing outer diameters and is designed to enable a high-quality surface finish. Features include adjustable burnishing pressure, a low-cost replaceable burnishing roll and standard, off-the-shelf availability.
