Slant-Bed Lathe Provides Rigidity, Stability, Precision
IMTS 2018: Racer Machinery International is displaying its Standard Modern CNC S-22 slant-bed lath, developed using hand-scraped surfaces, a built-in slant that offers more rigidity, thermal stability and precision.
Racer Machinery International is displaying its Standard Modern CNC S-22 slant-bed lath, developed using hand-scraped surfaces, a built-in slant that offers more rigidity, thermal stability and precision. In addition, three-point roller bearings, a dynamically balanced spindle, as well as ground precision ballscrews are standard. The S-22 is the most aesthetically pleasing addition to any shop floor.
The S-22 features a hydraulics system as well as automatic lubrication, coolant, chip conveyor and multiple windows to oversee parts in process. Operational ranges include a 22" swing over bed; a turning diameter of 22", 24" or 46"; a Z axis; and a 10-station VDI turret. The headstock has a A2-6 spindle nose, a 3.06" spindle bore and a 20-hp spindle drive that provides speed from 40 to 3,500 rpm. A gearbox is available as an option.
A significant feature is the machine’s Shop Turn programming software, which is designed to provide an intuitive conversational programming system. The user-friendly CNC makes this the ideal machine for manufacturers and training facilities, since its Siemens software package minimizes the effort required programming by using interactive graphics and simulations, according to the company.
