Soap For Machinists
Developed for machinists to prevent skin irritation resulting from contact with metalworking fluid, Uncle Earl’s Soap for Machinists is formulated to remove shop grease, oils and grime. Produced by Zebra Skimmers, a manufacturer of oil skimmers and fluid maintenance equipment, the soap is designed to alleviate dry, cracked and burning hands—a common problem associated with the use of metalworking fluids—without the use of abrasives or barrier creams.
Developed for machinists to prevent skin irritation resulting from contact with metalworking fluid, Uncle Earl’s Soap for Machinists is formulated to remove shop grease, oils and grime. Produced by Zebra Skimmers, a manufacturer of oil skimmers and fluid maintenance equipment, the soap is designed to alleviate dry, cracked and burning hands—a common problem associated with the use of metalworking fluids—without the use of abrasives or barrier creams. The soap, sold as a 3.5 oz bar, is made with all-natural ingredients and is said to last longer than a gallon of liquid soap.
3+3 Air Chuck Features Extended Stroke and Self-Centering
To keep up with the demands of the oil and gas industry, SMW Autoblok introduces BBFZA2G Air Chuck, featuring an extended stroke clamping range and three self-centering jaws.
4-way Bed Precision Lathe Features Automated Cycles
Long and thin workpieces can be machined without reclamping on this new machine from Weiler, according to the company.
Dielectric Oil Dramatically Reduces EDM Maintenance
Plagued by repeated small fires that interrupted its wire EDM throughput, this cutting tool manufacturer changed its dielectric oil and both eliminated fires and reduced its oil consumption.
