This dental implant manufacturer has found the right combination of technology and personnel to help implement its changing philosophy rooted in the control of its manufacturing processes.
With proper planning, knowledgeable personnel and access to the right tools, a company can significantly reduce outsourcing expenses by bringing certain operations in-house. For Sterngold (Attleboro, Massachusetts), a manufacturer of dental implants and restorative components, a change in company philosophy was the catalyst for such a move as management made the decision to bring back manufacturing of the majority of the company’s components.
In an effort for continuous improvement and to achieve optimum efficiency, Sterngold embarked on a program 2 years ago to expand internal manufacturing capabilities. Director of Operations Lee Clermont and Senior Engineer Bruce Seavey explained that until that point, the company relied on several outside vendors. “We saw a big benefit to shifting to in-house manufacturing to provide the ability to do rapid prototyping and bring new products to market more quickly,” says Mr. Clermont.
“Leadtimes also played a big part in our initiations,” Mr. Clermont says. “Some of our parts require small manufacturing runs, and the ability to schedule our own jobs allows for more flexible production.”
Adding Resources
The management realized that it needed additional staff before it could make the change to in-house production and so hired designer and engineer Bruce Seavey and machinist John Souza. “These appointments have been crucial to our new approach,” Mr. Clermont says. “They are both experienced in their field, of course, but the main benefit has been the way in which they work together to develop products that not only meet our customers’ needs but that can also be manufactured cost-effectively.”
Sterngold installed the first of its new machines early in 2006. Mr. Clermont and Mr. Seavey chose Citizen equipment because they believed it would allow faster setups—an essential requirement given the number of small runs being produced. The second machine followed in November of that year, and a third in 2007. The company’s current plan is to add a new machine each year as production increases. External machining is now down to around 10 percent of total production.
Software Solution
Beyond the machines, a significant reason why Sterngold has had so much success with its transition to in-house production has been the implementation of Delcam’s PartMaker software. The main components the company machines are its ERA family of resilient dental attachments. The range includes a number of angled attachments that are needed to give a strong hold where the underlying bone is thinner. Creating these complex angles would be extremely difficult with manual programming on the machines, even if multiple setups were used. In contrast, with PartMaker the company can create a program to make the parts in one operation and run a simulation to check what will actually happen on the machine.
“With PartMaker and the Citizen machines, we can not only produce the complete part on one machine but also use the two spindles to minimize the cycle time,” Mr. Souza says. “Using conventional methods, we would need two machines and a special fixture on the second machine. With the Citizen machine, we can produce a complete part in about 4 minutes. It would take that long on each of the two machines with a conventional approach. In addition, making parts in one operation is more accurate than using fixtures.”
As well as being small and having to be machined to tight tolerances, the design of the attachments makes them difficult to hold in the machine. Together, these factors mean that each pass has to be as little as one or two thousandths of an inch. “That’s a lot of tool paths to calculate without any software,” according to Mr. Souza. “There are also tough shapes such as threads on tapered radii that are difficult to work out manually but are easy to program in the
software.”
Mr. Souza admits that although Sterngold purchased PartMaker at the same time as its first Swiss machine, he did not start using it immediately. “We started out programming on the machines,” he says, “but we quickly realized that if Bruce (Seavey) and I collaborated in writing the programs, we’d be far more efficient.” Most of the programming is done off of solid models. Mr. Seavey draws the solid model in SolidWorks and then downloads it into PartMaker. Then Mr. Souza assists in implementing the different tools to use before plugging the program into the machine.
The ease of use of the software enabled Sterngold to ramp up production on the new machine more quickly than expected. “We scheduled three jobs to be completed in the first month after installation but completed them all in a week,” Mr. Souza remembers.
Another benefit of the software is the reduction in the time and difficulty of setting up the machines. “Because of our short runs, we are usually setting up a different part on at least one machine every day,” Mr. Souza says. “By doing our planning and testing on the software, we can reduce the machine time needed for setups by at least 40 percent.
“PartMaker has also allowed us to have our machine operators setting up our equipment for different parts,” he adds. “The software tells them which tools to load into the various positions on the machine. They don’t need to run any production trials or make any changes to the program as it has already been proved out on the software.”
Positive Results
Sterngold is sold on the reduction in setup time that the software has delivered. Mr. Seavey explains, “It’s easy to program. Any reduction is worth it, but with this software we’ve cut setup time almost in half. When you write a part program, it will tell you if you have any errors or tool crashes. While the machine’s running one part, we can be writing a program for another part. We’ll see errors beforehand and fix them before the part ever gets onto the machine.” Sterngold always does a dry run with the software to make sure there are no tooling issues and there will be no crashes. When a machine is free and is ready for a setup, most of the work is already finished. The operator plugs the program into the machine and runs a test part in brass with no coolant to watch the process and do any necessary fine-tuning. Mr. Seavey adds, “With this software, it’s almost like having an additional machine just for setups.”
Mr. Clermont explains how the benefits of the software work their way through the shop. “We run two shifts each day, but John can only work one of those. It’s his responsibility to get all three of the machines set up and running during the day and also make sure they’re ready to go for the night shift. Before we had the software, our machine operators weren’t able to do any setups. But with PartMaker, we can give the operators the programs and it turns them into setup people. In essence, most of the setup has already been done by Bruce and John on a computer.”
Mr. Seavey continues, “Without our preliminary work, the operator wouldn’t know how to program the codes on the machine. The software provides a shopping list of what tools to use. All the operator needs to do is put the tools into the machine. Typically the machine operator does just that; he operates the machine. He may know how to change a tool if it breaks, he keeps the bar feeder loaded, he hits the button, and he checks the parts coming off the machine. With much of the work done off-line, that operator now becomes a setup person as well.”
By assembling the right combination of technology and personnel, Sterngold has found a way to once again take control of its manufacturing processes and positively affect its bottom line. Planning and teamwork have been instrumental in making it happen.
Latest Version Launch
Delcam recently launched Version 8.6 of its PartMaker family of software with a number of features geared towards improving productivity across its range of application modules that include programming of turn-mill equipment and Swiss-type lathes, plus supporting software for milling, turning and wire EDM. The version includes enhanced solids-based programming, tool selection, surface machining and simulation. According to Hanan Fishman, president of Delcam’s PartMaker division, “The enhancements will make the programming of parts requiring multi-axis machining techniques more productive than ever before.”
For solids-based programming, this new version introduces the concept of “face planes.” When programming a part from an imported solid model, a face plane indicates very clearly the plane in which machining is occurring. Face planes simplify the programming of parts with multiple faces from solid models and improve visualization of the areas that need to be machined on a model. They simplify the definition of multiple coordinate systems in PartMaker, which allows the user to perform surface machining more easily across multiple parts or on multiple sides of the same part. Face planes also give the ability to set a view normal to any surface more quickly.
For cylindrical surfaces, a face plane can be displayed “wrapped” or “unwrapped.” The user can then specify the transfer of slots and holes for indexing or unwrapped geometry for cylindrical milling.
Other improvements to the software have been added for increased productivity. The Surface Machining Wizard offers improved machining strategies by adding axial step options to finishing and projection strategies, giving effectively nine more roughing strategies and more control in finishing operations. The ability to follow stock shape when needed has also been added. Additionally, 3D milling can now be performed in multiple coordinate systems on mills, especially useful for 3D milling applications on horizontal machining centers.
Version 8.6 supports the simulation of inclined turning tools used on lathes equipped with B-axis heads. It also supports the simulation of mini-turrets, which must be tipped on an angle when used in practice. This release also has a number of enhancements to grooving, including the ability to support inclined grooving.
Users can now automatically select a turning, grooving or threading tool in any turning profile machining strategy (such as turning, contouring, grooving, threading or cutoff). This feature assists in programming for operations such as turning with a grooving tool.
The Full Machine Simulation module now has the ability to support more complicated machine architectures than before, with more realistic visualizations and an expanded library of machine models.
