Software Enables Analysis of Tool Life, Chip Flow
Third Wave Systems has released version 7.2 of its AdvantEdge software including enhancements and capabilities designed to reduce the time required for tool-focused results analysis, communication and documentation.
Third Wave Systems has released version 7.2 of its AdvantEdge software including enhancements and capabilities designed to reduce the time required for tool-focused results analysis, communication and documentation. A new results analysis wizard includes walkthrough guides for analyzing tool life, chip flow and also enables the creation and printing of custom reports. This improvement is available for all simulation types and excels at multiple project comparisons. It works with most results created in previous versions and enables users to edit previously created reports when new data becomes available. Reports can be generated in .html or PDF format. In this version, 2D compression testing is added to the verification report.
The software is compatible with Windows 8.
How Integrated CAD/CAM Transforms Inventions Into Products
The close connection between CAD and CAM is what links creative ideas to practical production for this unique custom manufacturer.
Grinding Simulation Enables Growth in Custom Tooling
Simulation software both streamlines Gorilla Mill's grinding machine setups and speeds up the company's tooling design and verification processes.
Improve Machining Efficiency Through Digital Twin Simulation
Full simulation of a machining cycle using digital twins can not only identify crashes before they happen, but provide insights that enable the user to reduce cycle times.
