Software Saves Time, Prolongs Tool Life
Mastercam's Dynamic Machining is said to create a constantly adapting toolpath that delivers more-consistent cutting conditions and allows use of the entire tool flute length, often eliminating the need for multiple depth cuts.
New Product From: 4/12/2010 Modern Machine Shop
Mastercam's Dynamic Machining is said to create a constantly adapting toolpath that delivers more-consistent cutting conditions and allows use of the entire tool flute length, often eliminating the need for multiple depth cuts. This reduces cutting time and increases tool life, the company says.
The software also offers flexible retract options to keep the tool down in smaller parts and retract rapidly on larger parts. In addition, the custom “micro lift” option will retract the tool slightly off the bottom when moving to the next cut. This decreases the amount of heat generated in the part and also enhances chip evacuation.
Highly efficient entry methods along with customizable entry speeds and feeds enable flexibility, regardless of the material or cutter style being used. The software’s specialized motion can be used with both “closed” and “open” parts.
Mastercam / CNC Software, Inc.
MMS Zones
Zones
Supplier Categories
Get the Edge with iMachining - the revolution in CNC Machining. Time savings up to 70%!
• 2-5 Axis Milling
HSMXpress is full
featured 2 1/2-axis
CAM for SolidWorks.
Best of all, HSMXpress
is absolutely FREE!
SmartCAM V18.5 features New Mill/Turn Sub-Spindle and B-axis Support, Morph Pattern Roughing.
Increase your productivity and bottom line with SURFCAM!
www.surfcam.com
Simulate, verify, & optimize CNC machines with VERICUT
