Solid Carbide End Mills Reduce Chatter
Niagara Cutter will display its line of solid carbide Stabilizer end mills. The end mills feature specially engineered, variable-flute geometries designed to reduce distorting harmonics and chatter.
New Product From: 6/7/2013 Modern Machine Shop
Niagara Cutter will display its line of solid carbide Stabilizer end mills. The end mills feature specially engineered, variable-flute geometries designed to reduce distorting harmonics and chatter. The design is said to enable greater depths-of-cut, faster speeds, heavier feeds and better surface finish, resulting in increased tool life and productivity. The end mills feature Microshield TiAlN coatings and are available in a range of configurations and sizes.
The company will also showcase its expanded line of DiamondPlus CVD diamond-coated end mills, designed for machining graphite, green ceramics, and composite materials such as MMC or CFRP, among others.
Niagara Cutter
Zones
Supplier Categories
Drilling, routing, milling, reaming.
AMAMCO Tool engineers custom tooling for your most critical applications.
ERIX tool saves up to 90% of the manufacturing time on back spotfacing and chamfering operations.
  • Techspex
