Solid Carbide Micro Drill Meets DIN 1899 Standards
Walter USA has released the DB130 Advance, its smallest solid carbide micro drill
Walter USA has released the DB130 Advance, its smallest solid carbide micro drill with diameters ranging from 0.004" to 0.06" (0.1 to 1.45 mm). With a point angle of 118 degrees and cylindrical shank, the drill meets DIN 1899 standards.
The drill delivers precision and process reliability thanks in part to its micro-grain carbide, which improves cutting edge formation for high-precision applications. Due to its standard range, the drill can be used universally in a range of ISO applications including steels, stainless steel, superalloys and hardened materials. This micro drill can find ready application in general machining, watchmaking, automotive and food, as well as in die and mold.
The Walter DB133 Supreme solid carbide drill is available for diameters of 0.02" (0.5 mm) and larger.
Form Tapping Improves Tool Life, Costs
Moving from cut tapping to form tapping for a notable application cut tooling costs at Siemens Energy and increased tool life a hundredfold.
Tungaloy Expands Drill System With Drill Sleeves
Adding drill sleeves to the standard lineup enhances drilling productivity of Swiss-type sliding-head automatic lathes.
