Spindles for Swiss Turning
The expanded Micro Line spindles for Swiss turning features 20-, 22- and 25-mm diameter models.
New Product From: 2/24/2011 Modern Machine Shop
The expanded Micro Line spindles for Swiss turning features 20-, 22- and 25-mm diameter models. The model HT 25S 60, which is 63.3-mm long, is suitable for space-constrained tool zones. Right-hand spindles are available. The spindles use synchronous, DC motors and operate at speeds as fast as 120,000 rpm. They are designed for machining applications involving micro-milling and drilling tools, as well as engraving and fine milling. They feature high rigidity and precision (less than 2 microns runout) to increase surface quality and machining accuracy, the company says.
The company also offers a rotary coupling system that enables the Micro Line high speed spindles to be used in turret-style machines. The rotary coupling provides support for all electrical and pneumatic requirements for the high speed spindles, with models available to support two or four spindles.
IBAG North America
IBAG North America
